I'm looking for the 1-2 and 3-4 shift levers. The "slot" on the bottem of the lever needs to be vertical. Not slanted on a 45 degree angle. The shifter used is a Hurst V gate shifter. Also a super shifter or OEM hurst shifter lever will work. Thanks Steve
My son will finish my bird before I do,(he's 3 yr's old)!!
You may want to look up the part number for the correct ones that you need. One thing I have learned about Hurst shifters, there are a TON of different levers & rods! And one thing I can also say, it's worth it to look and find the correct ones. Seems every 4-speed car I've ever looked at had the wrong/incorrect levers and or rods. However, when you have the correct ones, WOW what a difference!
