Posts: 82 |
I'm seeking dimensions for a standard door panel for a 68 coupe? Maybe someone out there has an unmounted door panel lying around next to a tape measure and can help me out.
Specifically: A) Window crank hole (center) to front edge of door panel. B) Window crank hole (center) to rear edge of door panel. C) Window crank hole (center) to bottom of door panel. D) Door latch hole (center) to front edge of door panel. E) Door latch hole (center) to rear edge of door panel. F) Door latch hole (center) to bottom of door panel. G) Entire door panel width ~3" up from bottom. H) Entire door panel width ~3" down from top.
Considering making custom door panels, and want to try for a close fit without lots of in/out fitting and re-cutting. I already have the upper metal lip that runs the length of the door and attaches the top of the panel to the door frame.
Thanks!
Learning as I go! Not stock, but doing as much as I can myself.
1968 Firebird Coupe in progress...
Posts: 3,049 Likes: 10
Posts: 3,049 Likes: 10 |
A = 7 3/8 B = 34 1/16 C = 12 7/16 D = 19 3/8 E = 22 1/16 F = 10 even G = 41 9/16 H = 40 9/16
Hope this helps.
Posts: 82 |
Perfect.
Thanks Jeff! Jason
You got it
2 members (Geoff, Jimc2002),
469
119
