I need a set of disc brake- compatible Rally II wheels for my Mayfair Maize/parchment deluxe 400HO car and wonder what the code is, as there seem some confusion in the online sources. I have factory discs on there of course but somewhere the wheels got swapped for the 1980-era obligatory 15's! If I redo the car I want bone stock and if I end up selling her I want to have most everything that is missing so the next guy/gal can do it right. Right now it is just wheels, a better bird glass, radio and front upper baffles...Any help on any of these is appreciated!
cool, I wasn't sure that JC would work, I thought they were only drum clearance!
1969 Firebird 350 Coupe, Rust free Texas body, formerly brown, now a TA clone with quality spoiler, latching hood and TA wheel; 1969 GTO Convertible Expresso Brown/Parchment(currently painted red). Both numbers matching. My first love was a Cameo White 67 326 Coupe, bought back in 1983, at the age of 17, for $1,200. Been hooked since on PONTIAC! Working on a 67 400 ragtop for customization-Gulf Turquoise/Parchment/400/4 spd! My winter project!
I think Vikki had a bunch of Rally II's for sale a while back. Don't remember what codes though. I also believe HN code 14x6's will work with disc. Those are from the early '70's Ventura if you don't need 'correct' ones. You can't see the codes with the trim rings on. FWIW
We must have different charts. Oh well, good luck!
Are you using stock '68 4 piston calipers or the single piston? If using single piston original or aftermarket, the stock wheels for '68 will not fit without mods.
I have a set of JC. They came from a drum brake car but are typically known as required for stock '68 with original disc brakes. They need restoration.
I have not taken the wheels off and I will look closely soon when I go to the storage garage. I own about 55 various rally 2 wheels mostly 15s but I will have to go thru what I have when the snow melts. I know I dont have JA or JK code since those 69 disc wheels are needed for my goat. Like a fool years ago I sold them and put the 15s on (1987) but back then it was what you did! LOL!
