Look at the center runners, below the 3 6. See the numbers 1 6...72cc, used on 1969 400 manual trans, other apps, high compression if untouched and installed on 400. Looks like date code is J017, so these would be a September 1970 (1971 model year) set. Should be close to same specs, though.
