i have a set of hooker competition headers (summit item number HOK-4902HKR) and the passenger side tube is pointing up and inward, a decent about to where its pointing right at the transmission crossmember, not exactly sure what the best way would be to get the pipe back on track. would really like to straighten it out before i put the subframe back on the car, will be much easier to fix not than when its under the car. Should i make a hard s pipe, slit the end of the header collector, i dont know, whats best to fix? did anyone else use these headers? i took the first set back and got another, so they are just made this way.
