I have a decent set of Pontiac engine mounts. I also have one engine pully, but I'd have to look what it is for.
I am in the market for a set of top Alt brackets for my 73 455, so the later 11 bolt water pump... I only have one arm on there now from my 67 400. So I need to pick up a later style set.
If a 67 power steering set up will work I have a complete one with the pump!I have the engine mount's, Might have alternator brackets and pulley's as well.. Thanks Bill Speer 520-490-9097
Great to see you on here. I should have the bracket that you need. Since I am not sure which one of the two you have on your motor take a look at these ebay item numbers.
