Howdy boyos. So I spent the last hour contorting my arms into unnatural angles to get to the 6 and 8 cylinder on this AC 350. The results don't seem great, and I am hoping someone here can confirm.
It's a "YE" code 350 (9.2:1 compression ratio). These were the measurements (at 1600 feet above sea level):
1: 120 3: 120 5: 100 7: 100
2: 120 4: 120 6: 100 8: 100
In other words, the two cylinders closest to the firewall on both sides were all consistently low. I did the oil thing after the low readings and there was no change.
From high school auto-shop, I believe I'm looking at either a head gasket issue (the adjacent cylinders reading low), or a stuck exhaust valve on all the low cylinders. Is this about right?
And more importantly, does this sound like an engine that is worth salvaging? I realize there's very little data here, but that's all I really have. The seller insisted the car was a daily driver, but I didn't take the chance. I towed it home and have only rolled it around my driveway. It does start, idle, and the exhaust is clear.
I guess I'm just trying to decide how steep of a hill I have in front of me here. Thanks!
1969 Firebird, 350-2v/350, Verdoro Green (?), Green vinyl, numbers matching, relatively unmolested. Needs a bit of everything.
well, all i can add is that any engine i ever work on, if any cylinder varies by more than 10 pdi up or down, i usually go for tearing it down, checking cylinders, rings, valves, usually turns out pretty accurate that it had weak cylinder or cylinders, so i did what i felt is needed, but 4 at 120 and 4 at 100, still makes me wonder
My 400 had only been driven a couple hundred miles in the previous 2 years before I bought it. Both 7 and 8 read low on leak down, the other six were right where they were supposed to be. Mechanic said to go out and run it 500-1000 miles, as long as i didn't see any overheating or oil loss and test it again. Two weeks and 600 miles later, all 8 were in the zone. He said he had seen it before with motors that sat around... me, I just felt lucky.
Thanks for the link and suggestion, Jeff. I have a vacuum gauge and I will definitely break it out -- maybe even today if I can tear myself away from work.
And speaking of work, I am realizing that -- if I had the option -- I would gladly spend time in the garage instead of the office.
Maybe I have OCD.
