Has anyone changed their motor mounts for their 326 motor? I bought 2 new ones, and they are way different than the ones that are currently on the car. My service manual shows ones similar to the 400 engine style. One website that I found says that the right side is the same as the 400 motor. The mounts that I bought are the same as the Anchor part# 2255 & 2256 http://www.showmetheparts.com/anchor/
but they won't even bolt to the bracket that holds the motor mounts. Does anyone know where I can get the correct ones?
I changed my 326 motor mounts I just used 400 ones they fitted fine now I have taken the 326 out and put a 350 in using the same 400 motor mounts.
67 Firebird 350, TH350 auto Convertible, B&M 3000 TC, 4bbl Edelbrock Performer carb and intake Black Jack headers,disc brake conversion. 10 bolt chevy axle with 3.73's and B&M Rachet shifter.
If you bought them off ebay I see where the mistake was made. They offer three different part numbers for first gen bird mounts. I just bought some standard replacements off performance years and the part number is #2254. Yes they take the same mount.
