Does anyone have their suspension apart? My car is currently all together and I didn't want to take it apart until I had all of the parts in hand. but in order for me to do that I was hoping that someone has their car taken apart currently.
I need a few measurements of the tie rods: Over all length from center of joint to center of joint Length of the adjuster length of the inner and outer tie rod from center of joint to the end of the threads. All threads should be 5/8" standard correct?
I know it would be easier to spend $170 bucks on the Baer Trackers, but I've found a MUCH more adjustable friendly way to do this and with a steel adjuster rather then aluminum. However I need those measurements before I can order anything.
Thanks! -Paul Z. 68 350 Coupe
1968 Pontiac Firebird (In the works: 440ci Pontiac + Doug Nash 5 speed + posi rear = 1320 and Corner Carver Wanna Be)
I just happen to have my entire front end apart right now. I will jot down some measurements and let you know.......
The outer tie rods are approximately 5 inches form the center of the joint to the end of the threads. The adjuster sleeves are 6 inches, and the inner tie rods are 8.5 inches from center of joint to the end of the threads. The measurement of the inner and outer assembly will very due to how far the threads are screwed in on the inner and outer.
