I am installing a center consoule in my 67 firebird. It orginally had a column shift with a 2 speed auto. I am installing a TH350 in it's place. is there a diagram for the center hole cut out in the center hump out there I can get? Thank You
The nice thing is that there are dimples in the tunnel stamping for the two holes for the forward bracket as well as the two rear holes for the screw in the compartment and the one under the rear cover. From these, measurements to the shifter opening can be made.
Since the TH350 was not available in '67, you will likely want to use the throttle bracket, kickdown cable, etc from a '69 TH350.
