Does the cross over get hotter than the head? I had a warning light with the sender on the left head and just installed a guage sender on the cross over. The temps are hotter than I expected. I don't know for sure but it looks like I am running around 220+ at the cross over. The motor is a 75 400. The warning light never come on. Any thoughts?
I think the idiot light takes somewhere between 230-250 degrees to come on. Water temps should be close to the same in the head or crossover as long as the pump is working.
