Posts: 57 |
Getting ready to fill my new brake system and was wondering if anyone thinks there is one brake fluid better than the other?
Posts: 3,049 Likes: 10
Posts: 3,049 Likes: 10 |
I used dot 3 synthetic. Car sits alot and the synthetic fluids are less apt to absorb moisture.
The way to go if you are filling the system for the first time.
Posts: 1,534 |
I like this because it doesn't have silicone but great wet/dry boiling points for cars that sit alot.
ATE Super Blue Racing Wet 536 Dry 392 (ATE TYP 200 is same as Super Blue except red in color)
Posts: 7,719 |
The way to go if you are filling the system for the first time. X2. DOT 3/4 synthetic
Posts: 11,905 |
Posts: 93 |
I just filled my system from dry....and I used the DOT 3/4 synthetic....funny thing I noticed though, all the brake fluid on the shelf was synthetic now....had no choice but to go that route. I'm sure I could have found the non-stuff at another parts store, but figured it must be OK to use since there was so many different brands that were all synthetic. Bleeding actually went pretty well....
2,192
74
