I used dot 3 synthetic. Car sits alot and the synthetic fluids are less apt to absorb moisture.
The way to go if you are filling the system for the first time.
X2. DOT 3/4 synthetic
I just filled my system from dry....and I used the DOT 3/4 synthetic....funny thing I noticed though, all the brake fluid on the shelf was synthetic now....had no choice but to go that route. I'm sure I could have found the non-stuff at another parts store, but figured it must be OK to use since there was so many different brands that were all synthetic. Bleeding actually went pretty well....
