Need an auto transmission crossmember for my 67'. I'm doing a T5 swap from my original three speed and the auto will fit it pretty close. PM me if you have one with price and location thanks!
Do you mean a TH400 crossmember? If you have a 3-speed manual the only other factory crossmember was for the TH400. All the other trannys (4-spd, TH350, ST300) used the one you already have.
Is there an easy way to ID the factory crossmember? My '67 is originally a Sprint6 3 speed manual. I have a couple crossmembers that came with the car. I want to use a Pontiac 389/TH350 combo.
