my 69 bird's windshield wipers won't work... Just pushing the switch over to wipe will not do anything. If i "HOLD" the switch over to wipe it will wipe fine. Sometimes the wipers will not work at all. It's a real flaky switch
My guess is that the switch is corroded? I already checked the motor.
Is there anybody who can chime in and offer some advice. What I am thinking about doing is taking the switch and checking for corrosion and cleaning it up. Will I have to take off the dash to do that?
Nah, you don't have to pull the dash apart. Jumper 12 volts across the wiper motor to be sure it's okay - I'm sure it will be. Bad motors usually don't only occasionally work - they either work or they don't. Sounds like a bad switch to me too.
you can unbolt the dash and slide it back far enough to change the switch.it is not easy on the 69 birds.you will need a 1/4 inch socket to remove the screws.if you need a good switch,you can get a repo that dont look nothing like the original or buy a good used one.i have some here if you need one.
