I am finally restoring my first car a 69 FB Conv originally a 350/2b and Turbo 350 and trying to decide what engine to use. I have been waiting 33 yrs to do this and the restoration will include a few modern improvements in the suspension area. The drive train will be a 5 or 6 speed and either a modern LS or a 69 400 RA 4 engine I have had for 33 yrs. My main question is are any of you having any luck with pump gas for the higher compression older performance engines?
My compression ratio works out to 10.0 to 1 for the 400, dished pistons, and Ram Air II heads I have.
I'm actually mixing premium and another gasoline to get the octane up to about 98. Runs well on that mix.
Running on pump gas was one of my requirements to my engine builder.
455 punched out to 467, E-brock aluminum heads, manifold and carb, roller cam.
490 HP at the flywheel after break-in on the builder's dyno. Runs all day on 93 octane.
Aluminum hds can go a full point higher cr vs iron. 68-70 round port hds i've had where closer to 68-69cc's vs performance 72cc d-ports(70 #12's excluded). Wouldnt use anything under 98-100 octane. If the engine needs rebuilt, easy to lower cr for 93 octane.
