Looking for advice on getting the front bumper aligned with the hood and fenders on a 67 convertible. ( As of now, the top of the bumper is a bit low from lining up with the front edge of the hood and also a bit pushed out from the front edge of the fenders, yet the bottom of the bumper seems to be too close to the valance ) In other words, I am looking to close up the upper and side "gaps" and increase the bottom gap for an overall tighter and even fit. Any know of the steps needed to achieve this ? Thanks, Tom
WITH YOUR HELP !, trying to put back together a factory 1967 convertible 400/TH400, softray glass, pw, ps, pb, ac, console, clock, safeguard speedo, remote and visor mirror(s), hood and trunk lamps, and custom trim options.(Rally II rims and hood tach had been added). THANK YOU ALL for any help, opinions, and/or advice. I'M GONNA NEED IT !
id check to see if there was some previous damage first. before you adjust them. the brackets tilt up and down and there are some bolts on the head litght buckets that will (when loosen) will move it side to side.
