Hello Gentlemen, It drives and has a 400 engine (not original) aluminum intake, edelbrock carb, New electronic distributor, and has a turbo 400 trans. The unnusal is that it is column shift. Has all the normal rust issue and needs floor pans, 4 quarter to golfball size holes throughout the r/side body, left side body need area between the door and rear wheel replace (my body guy(LOL) cut this area out about 18 inches up to remove previous damage (wreck). Car is running and drive-able. Car was originally white (now blue)and belonged to a state trooper in South Carolina, I am the third owner. There is no hidden areas on the car as dis-assembly was started and then stopped while I moved to Alabama. What I need is 5k cash (to pay it off) and a trade (gotta have a daily driver) I think the old bird is worth 8-9 k.
Your 5k hunch is probably ballpark. Maybe 8k a few years ago.
Pictures would help a lot.
Thanks guys but it looks like I might get to keep the ole bird. I will be needing some parts very very soon and I hope I can get some more fabulous help. Thanks again.
