I picked up a 69 convertible in a million pieces, got most of it back together. I bought a new pump motor, lines, & cylinders. I had the frame blasted & painted. Its time to put the top back together, but I have no idea about how it bolts in, some of the bolt holes are wallowed out in the body, can you put clips in them? Weld them up? What's the well, gutter? I guess I need to find the best place to get information. Thanks
Here is the fisher body manual for 1969 section 13 Folding Top. Tons of good info in there. Just make sure you are looking at the F body stuff as all the GM Fisher body types are in there.
Also here is Spike TV show Musclecar where they install a top on a 69 trans am clone. I watched this dozens of times and was my best resource that showed me what to do. The top install doesn't start until about 1/4 of the way through. You can drag the bar under the video to fast forward.
