Posts: 1,616 |
i'm using some parts from my drums to complete my disc brakes... . but i am missing the "big big upper bolt" / two lower bolts can be used but the upper single bolt is way bigger on the disc? / anyone know where i can get them? . i guess the bolt the dust shilded on
john v.
Posts: 1,616 |
can someone post some pics if they have them of the front disc set up?
john v.
Posts: 3,049 Likes: 10
Posts: 3,049 Likes: 10 |
try contacting "the right stuff" company, it's where alot of us got the conversion kits. i'm sure they have that big bolt you need.
Posts: 794 |
Not sure which bolt you mean. Might be as simple as going to a Napa parts place. Send me your e mail address I just did a conversion kit on mine ( brand new everything $280.00) craigslist If the bolt is something you re use. From the drum units I might have Bmock@pft-alexander.com
Posts: 7,495 Likes: 1
Posts: 7,495 Likes: 1 |
The bolt is different from drum to disc. I believe the depth of the threaded hole in the spindle is deeper for disc so the bolt is a different length.
Posts: 1,616 |
i found the fat stubby bolts... 1 each side.. . the lower two can be used from the drums.. . looks like the bearings are the same also.. . only thing i'm missing now is brakepads and brake caliper pins..
john v.
2,192
74
