Installing new 3.55 gears and posi and I'd like some opinions on this contact pattern.
I think the pattern is centered well toe-to-heel, but maybe not quite as deep into the gear mesh as I'd like.
But when I add pinion shim thickness and/or decrease backlash to try to get a deeper contact, the pattern only moves down towards the toe on the tooth drive side and doesn't seem to get any deeper. Any opinions? Thanks
