Hi, I'm going to do the same thing. Some things you need to consider is are your going for the ram air four set up or the ram air three. The ram air four has a bigger lower pan and won't fit if you have factory air conditioning. The ram air three has a smaller lower pan which will. Year one has a kit with all the parts. Hitracker
The best place to find a Ram Air Three air cleaner kit I've found is from Firebird Central. Great web site. I've bought several parts from them and there a good guys to deal with.
