My car finally got delivered yesterday (what an ordeal) and I noticed a little water had drained out near the passenger side kick panel vent (non/ac car) and some leaves were sticking out of the vent. How is this area supposed to drain? From my understanding, the water from the windsheild flows down into the cowl vent area, around the inlet for the kick panel vents, and then ...? I'm worried that I have a blockage somewhere that's holding water up and causing problems. Might have to add a few things to the list of bodywork I'm going to tackle this winter.
need to remove kick panel, pain in the rear..lol, clean out the area...luckily its easier on pass side...BUT , if that one is clogged, most likley very close to be on drivers side too, best to do both while at it.
