Does anyone have a choke thermostatic coil rod that goes from the carburator (Rochester 7028168)to the coil located at the exhaust manifold that they can part with? This is for a '68 FB 250 inline 6 OHC automatic trans. Or know of anything that will work? Not easy to start cold... as you can imagine. Choke Coil Rod
It is very hard to find an original. When everyone pulled the Sprint Manifolds for resale they typically forgot to keep all the linkages. Getting the manifolds is easy, getting the linkages is hard. I would get a piece of 1/8" metal dowel and bend one up while you look (which might take many years).
Thanks Berd, but I don't think that will work. I should have specified that I have the 2 speed automatic with 1 bbl. carb. I think the FN501CJ is for the quadrajet. Anywhere else I might look?
I guess I didn't realize you were looking for a rod on a 1BBL carb. Have you posted over on the OHC forum. I am sure there are plenty of folks that have converted over to a 4 BBL and may have one of these laying around. OBTW here is the link
