Brass plate on door Plastic plate on qtr. post Shim under plastic plate for 1/32 interference
Purchased shim kit from Cincy Auto Trim and the shim hole spacing fits the brass and not the plastic. The shim is shaped like the plastic plate. Fisher body shows the above.
I can tell you on my 67, the shims are under the brass plate on the door. So far the car has turned out to be pretty unmolested so I believe this is how they came from the factory.
