I'm running a new brake line from the master back to rear axle. I was told by 2 local parts stores that 3/16" line is fine. I told then i am using single piston disc brakes. Is this too small a line? Thanks Steveo
My son will finish my bird before I do,(he's 3 yr's old)!!
Yes it is a 1/4" line from the proportion valve to the rubber brake line that runs to the axle, then 3/16" out to the connections to the calipers/wheel cylinders. My front to rear brake line has a hold off valve on the frame rail, this prevents the rear from appling too soon, I don't know what app you have, but look into it and research it out as I did when I redid my brakes, it is my life I would be saving if they work properly, someone removed my rear hold off valve and disc brake metering valve, always wondered why she would lock up and slide
