I will get a front end alignment tomorrow. Does anyone know the best spec's to use? I have 15" radial tires and a larger sway bar. Would like to use modern spec's vs. 1969 spec's. Thanks.
I had mine set to factory specs per the service manual, 15" weld wheels, factory sway bar and drives straight as an arrow now....
I will look for the specs in my manual.
