Do a simple test. Unplug the temp sender and read the guage. Ground the lead of the temp sender to the block and read the guage. If its not moving then you may need to remove the guage cluster and trouble shoot from that end.
thanks rohrt i will try that tomorrow been reading that there is a different harnest for gauges and idiot lights dose anyone know what the difference is brian
