I need the brackets and pulleys for a V8 with power steering and no air. I'll take air pulleys, I just don't need them.
I am putting a 389 in my car and have a mish mash of pulleys that don't line up, so I figure if everything comes from the same donor car, I will be fine. I currently have a '69 4 inch, 11 bolt water pump, but I will put a water pump for whatever the donor is.
I manufacture the alt brackets and also some of the other brackets that go on the system. Let me know what you end up with and maybe I'll be able to help you out with the brackets that you don't have.
