I know there is a gasket between the lens and outer housing. But is there a gasket between the housing/lens group and the body panel. Sure seems like there should be but darned if I can find a listing for it if there is.
Thanks
1969 Firebird Coupe 350/AT 1965 Tempest Coupe 215/AT
Only one gasket as far as I've seen. The outer bezel and housing/lens form a 'sandwich' with the gasket and body opening in between. The housing/lens protrudes through the opening and is sealed against the body by the gasket.
