I have a 1968 firebird, I believe the dash has been switched out, but does anyone know what this knob/dial does? It seems to have three clicks, maybe low/med/high.
YEP! That's what it is! Thank you. I saw on the window sticker that it came with rear window defogger. It also said they added a clock, but there is not one in the dash, that's why I think the dash may have been switched out. Thanks again Daryl_keys
Clock should have been console mounted...I think???
Yes. And, if I recall, w/o a console it was floor mounted in about the same spot. If a 8-track was ordered you could not get a clock because they would occupy the same area.
Gent's here is one that also has a bench front seat. Tough to find a new cover because it is not common. Any idea who makes a new front bench cover? Thanks
