WITH YOUR HELP !, trying to put back together a factory 1967 convertible 400/TH400, softray glass, pw, ps, pb, ac, console, clock, safeguard speedo, remote and visor mirror(s), hood and trunk lamps, and custom trim options.(Rally II rims and hood tach had been added). THANK YOU ALL for any help, opinions, and/or advice. I'M GONNA NEED IT !
It is attached with pins on the back that are held by spring loaded clips in the door face.
So you have to pry it up gently and evenly. Plastic pry bars (Eastwoods) or plastic putty knives work well. In a pinch you could sand sharp edges on popsickle sticks and use them.
