Why does the console gear shift on my 69 firebird 400 with Turbo hydra matic auto trans have additional linkage from the trans to the back of the steering column? Is it part of an electronic safety switch assembly or did my bird originally come with column shift?
they all are designed w column shift ,then a linkage to the console...if you check the column when you use the shifter ,you`ll see it move...that part is for back up light and park lock, as thats the stock set up
