-----Original Message----- From: techsupport@lunatipower.com [mailto:techsupport@lunatipower.com] Sent: Monday, January 07, 2013 8:54 AM To: spochon@lunatipower.com Subject: Cam Recommendation from Website
ENGINE INFORMATION Engine Year: 1969 Engine Manufacturer: Pontiac Engine Factory Cubic Inches: 355 Engine Current Cubic Inches: 355 Engine Compression Ratio: 9.2 Piston Bore Diameter: 3.750 Connecting Rod Length: 4 Crankshaft Stroke: Desired RPM Range From: 1500 Desired RPM Range To: 5200
INDUCTION Intake Manifold Type: Edelbrock Performer Ported Cylinder Heads: No
CYLINDER HEADS Cylinder Head Manufacturer: Pontiac Cylinder Head Material: Cast Iron Head Runner Volume: 150cc Intake Valve Size: 1.96 Exhaust Valve Size: 1.66 Ported Heads: Yes Rocker Arm Ratio: 1.5 Adjustable Valvetrain: No Maximum Valve Lift Capacity:
FUEL DELIVERY Fuel Delivery System Type: Carbureted Fuel Injector Or Carb Size: 750 QuadraJet Fuel Type: Pump Gas Unleaded Fuel Octane Rating: 91
POWER ADDERS Super Charger: No Super Charger Type: Centrifugal Supercharger Boost Amount: Turbo Charger: No Turbo Charger Count: One Turbo Charger Size: Turbo Boost Amount: Nitrous: No Nitrous Amount: Nitrous Stages:
CURRENT SETUP Current Cam Manufacturer: Pontiac Current Intake Duration: Current Exhaust Duration: Current Advertised Intake Duration: 269 Current Advertised Exhaust Duration: 277 Current Intake Valve Lift: .375 Current Exhaust Valve Lift: .410 Current Lobe Separation: Current Intake Centerline: Area For Improvement: More Upper RPM Power
COMMENTS Comments: I might try to bump up the compression to 9.5 if that makes a crucial difference in cam choice. I want a cam that will help get me to 330 horsepower and at least 15 mpg at 60 mph at 70F. Also my phone is down, so email is preferred. thanks for your time,
1) need higher stall convertor(for sure) 2) I like cam no 1, but with 110 lobe seperation 3) BUT, the exhaust lift on cam no 1 may be too much for standard poncho head set up. I think .46 is about the max. 4) go roller
Contact Butler or SD performace. They will give you good info.
