Just finished cleaning up the trunk area and spraying on the correct spatter paint. I found a thread debating whether the trunk drain plugs are installed pocket side up or down(mine were both pocket side down/bump up). My question is what type of seam sealer or caulking would be proper or correct to use...or did it use some type of gasket material??
