2nd line (raised circle). That lip is there specifically to prevent you from going too far.
You might want to try removing the grommet, put the PCV through the grommet and the grommet back into the valley pan.
If the grommet is old and brittle, forget it. Also try coating the PCV valve with a thin film of motor oil.
Sorry, but I have a Edelbrock manifold with the PCV slot in the front and a matching aluminum valley pan from Butler. Makes getting to the PCV valve a LOT easier.
The rubber should be some what pliable. Put a thin coat of oil on valve and push/twist/wiggle. Like salmon said, if hard and/or brittle, need a new one.
