I have a few questions concerning the front window cranks on a 68 with a black custom interior. I did a search and couldn't find consistent results.
1. Are the cranks different (more arch) on the custom door panels compared to the standard panels? I was hoping someone could provide pics of cranks that are known to be original/correct of the two interiors.
2. What color should the knobs be?
3. I've seen window crank springs in catalogs. Do they go over or under the panels? What's their purpose?
The deluxe door crank studs are longer than standard studs. (deluxe panels are thicker)
Knobs generally match the door panel (interior) color.
Springs go between the panel and the inner crank assembly. They hold the panels away from the door inner frame. There is a plastic "washer" that goes between the back of the crank handle and the door panel.
