#266012 03/22/13 05:57 PM
T Offline
Does anyone know of a source for the split tubing used on the rear body harness?
Carmutt was looking for that last year. I never heard if he found any or not.
would any of the split tubing work at American wire?
http://www.americanautowire.com/shop/?action=add&p=1&vehicle=1968%3BPONTIAC%3BFIREBIRD
Here is a link to what American auto wire has
Split wire loom
I also used this once. It is solid and not spit but maybe it can be spit ourselves.
Sleeve
U
U Offline
You can also pick that stuff up at Auto zone or any auto parts place
T Offline
Thanks for the info the Metric Harness Sleeving looks pretty close and could be split. All the stuff I've found at Autozone is just the convoluted tubing that disintegrates when touched after a few years.
T Offline
Found a pretty close match, just the tubing wall is a bit thicker. Vinyl tubing in 50ft x 1/2in from home depot used for above ground sprinkler systems. Just split the tubing and it overlaps like the factory stuff.
