Its a filler panel found on 400 and a/c cars to help direct more air towards the radiator.There,is that 1000?
David
Yes its the one typcally called the X filler...or "core support filler , FP191 J in Ames cat. you should also have the rubber or masticated fillers (FP454) in conjunction w those, plus the lower baffle ( FP191L)IF you have a 400 or A/C car
a 350 non a/c shouldnt need it...if your temp is too high , you probably should look at 'fixing' the waterpump impeller...or radiator , but impeller is probably the culprit
I would put a set on just because it looks so much better under the hood with them, even though it may not need them to help cool the engine. Looks kinda barren without them!
