Good morning, I like to remove the fenders and inner fenders as one piece. Start with the hood, then the front valence below the bumper. Then remove the bumper assembly by removing the 4 bolts that hold the bumper brackets to the frame and the two nuts that hold the upper bumper reinforcement to the fender gussets , this will also remove your headlight bezels. Then 5 bolts to hold the inner fender to the rad support and rear brackets in the wheelhouses, remove the battery tray. Finally 5 bolts at the back of the fender, and two bolts at the front and two large Phillips head screws in the gusset. tape your shims together in groups and mark the location where they came from. Good luck! ps. lots of penetrating fluid.
