M Offline
It's a slow leak thats coming from underneath the dashboard. There is a small pin at the bottom and it kind of looks like the head of a nail. Any suggestions? Thanks!
1967 Pontiac Firebird 400 4 Speed Convertible
1973 Opel GT
[Linked Image from i116.photobucket.com]
the only thing under the dash is the heater core.
M Offline
Ok. Expensive to replace?
1973 Opel GT
M Offline
It's leaking from the bottom through a pin-like hole.
1973 Opel GT
There have been qite a few threads about replacing the core from the inside of the car. I think Wouter did a picture tutorial a couple of years ago.
first , just disconnect it , by pass it...its not an urgent need to have that heater in Calif. or Texas...lol
M Offline
Thanks!
1973 Opel GT
T Offline
Just disconnecting it could cause cooling problems. You need to bypass it by running the hose from the back of the head to the water pump.
Plugging the lines is better. That way the coolant travels through the head instead of the hose. Bypassing is also fine.
