Two (2) Edelbrock Performer IAS (Red) 34981 shock absorbers. These boxes were opened prior to my purchase, but I have verified they are new and have never been used or installed. These shocks are no longer being made and are almost impossible to find! Check out the user review for these shocks and you will not be disappointed!
Product Description
Only Edelbrock shocks feature Ricors patented Inertia Active System (IAS). This exclusive design switches instantly between a firm and a soft circuit for superior handling and a smooth ride. There is no other shock that can deliver this kind of performance, because no other shock has this patented valve. Until now, if you wanted to reduce chassis roll around turns and under hard braking, yet have a comfortable ride you couldnt do it. No shock absorber in existence could do both without some compromise in either handling or comfort. When you improved the handling with stiffer shocks, the ride became rough and uncomfortable. When you improved the ride with softer shocks, the handling became sloppy. That is, until now The revolutionary Edelbrock shocks deliver excellent handling and a comfortable ride. The patented Ricor Inertia Active System eliminates the compromise inherent in other designs for a shock that is soft on rough roads and firm on smooth roads. This keeps the tires on the ground and the chassis stable. You may have heard these claims before, but now its for real. With Edelbrock, you get The Best of Both Worlds superior handling and maximum comfort!
$200 plusProduct Features
Shocks use polyurethane bushings for added responsiveness High-pressure mono-tube design eliminates oil foaming Includes nitro-steel piston rods and heavy-duty welds Comes with an attractive red powder coated finish with the Edelbrock logo Facilitates a smooth and comfortable ride in demanding off-road conditions
1967 Pontiac Firebird 400 4 Speed Convertible 1973 Opel GT
