I'm in the process of restomoding my 67 and the seam sealer (i think that's what it is) on the firewall is dry-rotted and cracked. what can be done to fix this? do I peel the old stuff out, then reseal? if so what do I use?
The seam sealer comes from any one of the various Pontiac parts vendors such as Ames, Classic Industries, Year One, etc. It comes in a caulk gun tube. I try and get the one made by 3M.
Or if you want to do it once and for all you can clean out all the old seam sealer and then clean it with a wire brush then stitch weld the entire seem and grind it smooth. More work, but you won't ever have to replace the seam sealer again.
