67 M20 complete setup The M20 I pulled from my 67 SS 350 need a good home. Car wasn't running when I got it, had two toasted rod bearings, suspect the tranny works but is probably well worn. comes with every thing, flywheel, clutch, pressure plate, TO bearing, bell housing,tranny, shifter, crossmember, z bar & brackets, speedo cable, bolts, clips, grommet,reverse switch, I'll even throw in standard steering column. Asking $800 local pickup only please.zip code78070 Thanks, I'm moving and don't want to jack with it, My health went south on me quickly. Ron
