Metro is what most people get since its the closest to original, however I just saw an ad in HPP that showed some new door weathstiping from Rubber steel products that look like they may have a better product.
The description says: Only seals with brass core that strengthens and prevents rust Sponge molded ends ensures the door will close Pre-installed pins makes installation easy Perimeter rubber cut to length
I used Steele weather stripping. It was pliable and easy to adjust panels. After fighting with the OER stuff, this worked good. The OER stripping is too stiff.
