I am curious to know if anyone would be willing to post pics of their clutch replacement? I'm currently converting from automatic to manual and encountering some challanges with the frame bracket for the z-bar, clutch fork return spring bracket. Specifically, the 3 frame bracket holes are there, but there is no nut to turn bolts into. There seems to be other spots on the frame where a nut is welded to the inside of the frame.
I did that same swap ten years or so back. I don't have any pics but I do remember that the three holes for the frame bracket were ready for the bolts. I think they were tapped without an actual nut welded on. I also remember that there was an issue with the return spring bracket but I found that I had the wrong one. Sorry, no pics of that either. Hope this helps.
