Not sure I understand the problem. Do you mean when you turn lights on and drive car the battery eventually drains down to the point you will need a "jump" next time you need to start it?
Check for clean contacts on battery Check battery to see if it's got good cranking amps Check Alternator to see if it's charging the battery when engine on
Recently replaced my voltage regulator, jumper the number 2 and number 4 wire going to the regulator and checked the voltage at the battery, was pushing 17 volts, so I knew the alternator was good. One thing to look out for; my old regulator had a ground wire, so reused it with the new regulator, was grounding out, worked fine after removing the ground wire.
