#272927 07/14/13 07:48 PM
I've seen the top and sides of the cowl both in 60% gloss black and in body color. The Camaro restoration guide has it in body color. The Firebird restoration guide does not list it at all.
I'm thinking it was in black but seeing many in body color. Any idea what color it was?
HaroldB #272932 07/14/13 09:08 PM
Are you talking about the area under the cowl. If so it is black.
Larry
1967 Sprint Convertible
hokie1984 #272933 07/14/13 09:13 PM
The area above the firewall where it runs to the windshield and down the sides behind the door.
HaroldB #272934 07/14/13 09:17 PM
Yes it is black. At least on the 1967s.
Larry
hokie1984 #272941 07/14/13 09:55 PM
I've read the door hinges were body color. It seems strange that the door jams and hinges were body color and the side cowl was black behind the door where the hinges bolt on.
HaroldB #272979 07/15/13 10:46 AM
The part where the hinges are bolted, I believe, is painted body color. Mine has been repainted there so I am not absolutely sure.
Larry
hokie1984 #272986 07/15/13 11:34 AM
Got it. Thanks.
HaroldB #272988 07/15/13 01:29 PM
My guess, based on the Camaro Assembly Process at the Camaro Research Group's website - is that the body shell was 1st totally painted body color and then line workers sprayed the semi-gloss black over the body color on the firewall.
Thus the stop line of the black paint probably varied by vehicle.
1980 Turbo Trans Am
1988 Mustang GT, 5 speed
1983 F-150 4x4, built 302
salmon38 #272994 07/15/13 03:03 PM
That is what my researched reviled too. I reading a article now from Hemings muscle machine nov 2011 on a 68 400 conv. He painted the top and sides body color. He was doing a concours restore pretty much. He has taken 998 out 100 at the trans am nationals in 2009. I guess either way is fine.
Mine appeared to be black but who knows after 45 years and what might have been done.
HaroldB #272995 07/15/13 03:14 PM
Also, according to CRG, the doors and trunk were installed on the body shell prior to shell painting.
1980 Turbo Trans Am
salmon38 #273014 07/15/13 07:34 PM
Nice to see that in print. My cowl is painted top coat color and the top and bottom. Then the black spray sounds right to me. The top coat remained on my cowl on the outside portion that is covered by the fender.
Thanks for the link Salmon. Great doc to follow. I think it will make putting it together easy as well.
2006 Sequoia
2017 Murano (wife's car)
202? Electric car
HaroldB #273015 07/15/13 07:41 PM
Harold,
The front end work you have done looks awesome. Lots of fun putting it together when the final product looks that good ehh?
2006 Sequoia
202? Electric car
Gus68 #273019 07/15/13 07:55 PM
Originally Posted By Gus68
Harold,
Thanks. Yes it is great seeing it going back together.
HaroldB #273020 07/15/13 07:57 PM
I have a bunch of pics uploaded on my Google account of Firebirds with pretty good stock restoration of the suspension and engines.
Here is an example. You should be able to find my other "Publc" photo albums I think.
https://plus.google.com/u/0/photos/105908860112140983297/albums/5899076407881417665
2006 Sequoia
202? Electric car
Gus68 #273036 07/15/13 11:29 PM
Thanks. I've been checking them out. Lot of good pics there and great cars.
Gus68 #273069 07/16/13 12:55 PM
You're welcome. I should have remembered that site a bit earlier for you.
1980 Turbo Trans Am
salmon38 #273109 07/17/13 12:14 AM
I have a firebird mystery for you, i posted this subject four years ago.
my 69 is white, has had one repaint the same color. the cowl and firewall on it has a teal green shade of paint on the fire wall and cowl area. under the green is the correct black.
What paint codes are on the trim tag?
1980 Turbo Trans Am
salmon38 #273127 07/17/13 10:57 AM
"50 B" on the trim tag
Interesting. My guess is a previous owner did the green paint for some reason.
1980 Turbo Trans Am
salmon38 #273156 07/17/13 05:02 PM
no it came from the factory like that. i had a post on it in 09. a camaro research guy said that he had seen a couple of camaro's from the Van nuys Ca. plant come out like that.
the engine has never been out until i removed it to reseal every thing. it came with paper work for maintenance performed on it. it was a one owner, black plate, dealer tag frame ect...
its a mystery to me. i had the engine out pressure washing the engine bay noticed two colors on the fire wall and quit washing with pressure. i left it the way it was.
this bird is more original than the two i had in the late 70's, early 80's.
Mine is body color on my coupe and convertible with some black overspray
86 Pontiac 2+2
salmon38 #273424 07/23/13 12:01 PM
Salmon, Do we know that the Camaro assembly process was pretty much the same for our firebirds?
HaroldB #273427 07/23/13 12:17 PM
We can't say that for sure - but it should have been similar. Looks like Firebird and Camaro were not assembled on the same line until April 1969 according to the CRG.
That means that Firebird assembly was by itself at Lordstown until Norwood and Van Nuys were added where it shared the line with Camaros.
1980 Turbo Trans Am
salmon38 #273437 07/23/13 01:03 PM
If I can help I will. My Oct 68 69FB was built in Van Nuys and has had one respray in 86. The painter did a crappy job but never removed much to do the job. Under the cowl should be the factory paint and colors.
If it can be done I will pop the wiper arms off and lift the cowl up enough to peek inside. If I can take pics I will.
Will this work?
69 OHC ZH Sprint Hurst 3 Speed 3:55
OHC Forum http://sohcsix.yuku.com/
WANTED: 1969 OHC Sprint "H" Camshaft
HaroldB #276479 09/22/13 04:09 AM
K
K Offline
There was a standardized GM plant layout and all GM products were assembled pretty much the same way. Minor variations for various reasons, but not much. That article is specifically written to cover other GM models. Look at the 1959 Life pictures - same process!
You can always ask John. He was there - he's standing on the far left talking to the production manager in the pic of the red 69 Firebird.
http://camaros.org/assemblyprocess.shtml#chevmetal
Kurt S
CRG - www.camaros.org
