me too, i found some at the local parts store that have the ground wire, ill go with those if i cant find the original kind. only other place i found them was with the wiring kits and you have to buy the whole kit
Chondro, good to see another Bird in MN. I don't see too many around here. What auto part store did you find those at? I don't need the correct ones, I just want ones that will stay in the housing without having to silicone them in so they won't fall out. Thanks...Dan
Doug, they are different from most i have personally seen.They have metal tabs around the socket that hold it in place when pushed in the marker light housing.They also seem a little larger,not much,but enough to make a different one need to be held in place with some sort of adhesive.I have them on my harness but somewhere along the line the holes were covered/quarter section was replaced so i don't currently use them.
David
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Chondro and Derding... it's good to live up in God's country, cuz that makes our birds even cooler! </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Being in Minnesota, doesn't that make most EVERYTHING cooler?
Thomas, I checked all my resto catalogs and find no repros. For used, I usually check two sources: Chicago Muscle Car Parts http://www.cmcponline.com/ (he is generally pricy but often has the used parts) and FirebirdBill at earlybrds@aol.com and keep checking EBay Jim
