top cylinders
top cylinders
273177
07/17/13
11:14 PM
May 2012
Southern Ontario Canada
69 softtop
69 softtop
May 2012
Replacing the cylinders on the power top of my 69 bird. Any suggestions on how to get the outer pin out? Seems more tedious than need be. Thanks
Re: top cylinders
69 softtop
273198
07/18/13
10:57 AM
Oct 2009
Virginia
hokie1984
hokie1984
Oct 2009
Virginia
What you will want to do is push the bolt as far towards the outside of the car as possible. At the same time rotate the cylinder and individually remove the plastic washers. It should then come out. It sounds uglier than it looks.
Larry
1967 Sprint Convertible
1 members (
Highlander
), 1,046 guests, and 18 robots.
